Hvilken driver till hva? !
Har 9700pro sapphire, nå lurer jeg noe sinnsykt på hvor, hva, hvilke drivere jeg trenger å hvor jeg får tak i den nyeste å beste??
(fant dette innlegget på ati`s sider)
RADEON 9700 PRO 128MB - Display drivers get overwritten using drivers provided on REMOTE WONDER CD 180-G01410-100
The REMOTE WONDER CD release 180-G01410-100 does not contain drivers for the RADEON 9700 PRO. To properly configure the correct driver version for the RADEON 9700 PRO, you must install the RADEON 9700 PRO drivers .
Please follow the recommended installation procedure below:
Install the RADEON 9700 PRO using the provided ATI INSTALLATION CD and Installation Guide.
Insert the ATI REMOTE WONDER INSTALLATION CD into your CD-ROM drive.
If the CD auto-starts, proceed to step 7.
Click Start.
Click Run.
Type the following: X:ATISETUP
(Where X represents the CD-ROM drive letter.)
Click OK.
Click ATI REMOTE WONDER option.
NOTE : Do NOT select the EASY INSTALL option.
Follow the Wizard's on-screen instructions to complete the installation.
INFO-BASE# 4073
KEYWORDS: RADEON 9700 for PC REMOTE WONDER DRIVER INSTALL
??????????????????????????????????????????????????????????????????????? :shrug::shrug::shrug::shrug::shrug::shrug::shrug::shrug:
