Wanisher Skrevet 23. mars 2003 Del Skrevet 23. mars 2003 hei skal kansje kjøpe nytt hoved kort, cpu og etter hvert nytt skjermkort (beholder kabinett og strømforsyning) dette er det jeg har nå, håper at noen ka hjelpe meg CPU INFORMATION ================ Number of CPU ------------------ 1 Manufacturer ------------------- GenuineIntel Processor ---------------------- Intel Pentium III Code Name ---------------------- Katmaï Package ------------------------ Slot 1 SECC2 Family ------------------------- 6 Model -------------------------- 7 Stepping ----------------------- 2 Core Revision ------------------ kB0 Extended Family/Model ---------- 0/0 Technology --------------------- 0.25µ Microcode Revision ------------- 10 Specification ------------------ Intel Pentium III 500MHz Instructions ------------------- MMX, SSE CPU Speed ---------------------- 501.2MHz Clock Multiplier --------------- 5.0x Front Side Bus ----------------- 100.2MHz Bus Speed ---------------------- 100.2MHz L1 Data cache ------------------ 16Kb L1 Code cache ------------------ 16Kb L2 cache ----------------------- 512Kb MAINBOARD INFORMATION ====================== Manufacturer ------------------- http://www.abit.com.tw Model (revision) --------------- i440BX-W977(BX6 Rev2.0) ( ) Chipset (revision)-------------- Intel i440BX/ZX (C1) Southbridge -------------------- Intel 82371 (PIIX4) BIOS Brand --------------------- BIOS Version ------------------- Award Software International, Inc. BIOS Date ---------------------- 04/07/1999 AGP Revision ------------------- 1.0 AGP Transfer Rate -------------- 2x AGP Aperture Size -------------- 64Mb AGP Side Band Addressing ------- enabled Display adapter Manufacturer --- ATI Model (revision) --------------- Rage 128 GL (0) MEMORY INFORMATION =================== Type --------------------------- SDRAM Size --------------------------- 320Mb # of memory modules ------------ 3 Module 0 ----------------------- SDRAM PC100 - 128 Mb Module 1 ----------------------- SDRAM PC100 Module 2 ----------------------- SDRAM PC125 - 128 Mb Frequency ---------------------- 100.2MHz CAS# Latency ------------------- 3.0 clocks RAS# to CAS# Delay ------------- 3 clocks RAS# Precharge Time ------------ 3 clocks DRAM Idle Timer ---------------- 32 clocks SYSTEM INFORMATION =================== Operating System --------------- Microsoft Windows XP (Build 2600 Lenke til kommentar
AMDguru1 Skrevet 23. mars 2003 Del Skrevet 23. mars 2003 Du må ha ny Ram også. forslag: Asus A7N8X AMD Athlon xp2200+ Twinmos 512mb Ram Lenke til kommentar
Admin'c Skrevet 23. mars 2003 Del Skrevet 23. mars 2003 jamen så ille det er, er ike dette den tredje slike posten? hvis du skal ha ny cpu trenger du nytt hk og ram, sleng på et skjermkort så har du ny maskin. Et kabinett også så har du to maskiner Lenke til kommentar
