trenger hvelp til "bit for bit" data
Wanisher
hei skal kjøpe kansje kjøpr nytt hocved kort cpu og etter hverrt nytt skjerkort (beholder kabinett og strømforsyning dette er det jeg har nå
CPU INFORMATION
Number of CPU ------------------ 1
Manufacturer ------------------- GenuineIntel
Processor ---------------------- Intel Pentium III
Code Name ---------------------- Katmaï
Package ------------------------ Slot 1 SECC2
Family ------------------------- 6
Model -------------------------- 7
Stepping ----------------------- 2
Core Revision ------------------ kB0
Extended Family/Model ---------- 0/0
Technology --------------------- 0.25µ
Microcode Revision ------------- 10
Specification ------------------ Intel Pentium III 500MHz
Instructions ------------------- MMX, SSE
CPU Speed ---------------------- 501.2MHz
Clock Multiplier --------------- 5.0x
Front Side Bus ----------------- 100.2MHz
Bus Speed ---------------------- 100.2MHz
L1 Data cache ------------------ 16Kb
L1 Code cache ------------------ 16Kb
L2 cache ----------------------- 512Kb
MAINBOARD INFORMATION
Manufacturer ------------------- http://www.abit.com.tw
Model (revision) --------------- i440BX-W977(BX6 Rev2.0) ( )
Chipset (revision)-------------- Intel i440BX/ZX (C1)
Southbridge -------------------- Intel 82371 (PIIX4)
BIOS Brand ---------------------
BIOS Version ------------------- Award Software International, Inc.
BIOS Date ---------------------- 04/07/1999
AGP Revision ------------------- 1.0
AGP Transfer Rate -------------- 2x
AGP Aperture Size -------------- 64Mb
AGP Side Band Addressing ------- enabled
Display adapter Manufacturer --- ATI
Model (revision) --------------- Rage 128 GL (0)
MEMORY INFORMATION
Type --------------------------- SDRAM
Size --------------------------- 320Mb
# of memory modules ------------ 3
Module 0 ----------------------- SDRAM PC100 - 128 Mb
Module 1 ----------------------- SDRAM PC100
Module 2 ----------------------- SDRAM PC125 - 128 Mb
Frequency ---------------------- 100.2MHz
CAS# Latency ------------------- 3.0 clocks
RAS# to CAS# Delay ------------- 3 clocks
RAS# Precharge Time ------------ 3 clocks
DRAM Idle Timer ---------------- 32 clocks
SYSTEM INFORMATION
Operating System --------------- Microsoft Windows XP (Build 2600
Gratulerer med hele 5 skrivefeil på èn linje.
Skal du plage andre med å påpeke hvor mange skrivefeil de har bør du ihvertfall være i stand til å telle. Det er faktisk ikke fem skrivefeil, det er syv hvis du ikke regner med mangel på stor bokstav.
kansje=1
kjøpr=2
hocved=3
hverrt=4
skjerkort=5
Tok ikke med at hovedkort og etterhvert var splittet opp. Men på grunn av mye cut'n'paste ble gjennomsnittet i innlegget ganske bra i forhold til mange innlegg her på forumet.
Hvis du ikke har råd til å kjøpe alt dette nå, kan du jo forsøke å presse norsklæreren din for en del penger. Regner med at du har en ganske bra erstatningssak...
"Kjøpe" en gang for mye (6) og "hovedkort" skal ikke deles opp (7). Etter hvert skal imidlertid skrives som to ord. Ser ut som du også har noe å hente av å presse norsklæreren din. Det skal forresten ikke være komma i din andre setning. Forøvrig fra Nettikette:
"En kritiserer aldri andre for skrivefeil eller grammatiske feil."
Tok ikke med at "kjøpe" var skrevet en gang for mye, ettersom det tross alt var stavet riktig. Ettersom du er langt mer kritisk enn meg burde du vel også ha påpekt kommaet som mangler etter "hovedkort".
Mitt eget komma vil jeg derimot ha der det er. Men jeg må legge meg flat for "etter hvert". Skjønner ikke hva jeg tenkte på...
Jeg kritiserte jo ikke skrivefeilene, jeg gratulerte. Og der er det en stor forskjell!
Mangel på komma er en tegnsettingsfeil, derfor tok jeg den ikke med. Du kan fortsatt ha lyst til å ha med kommaet i din setning men det er fortsatt feil. Men hovedpoenget ser du ut til å ha gått glipp av: Hold kjeft om andres skrivefeil. Har du noe å si om det så send en PM.
Kan ikke se å ha mottatt en PM om dette, så vi er tydeligvis to om å ha gått glipp av hovedpoenget.
Kunne ikke dy meg for å påpeke det bittelille tegnet som skulle ha stått der et sted... :)
Vel ... skal du ha deg noe P4/AMD XP så tror jeg også strømforyninga må byttes ut ... Grunnen er todelt. For det første drar P3 og alle tidligere CPUer strøm fra +5V-kursen i strømforsyninga, og ergo er disse kraftige på P3-strømforyninger. P4, AMD XP og nyere drar alle strøm fra +12V-kursen, samme som harddisker, brennere, DVD-rom etc. På strømforsyniger laget for P4/AMD XP er da +12V-kursen styrket i forhold til det de var i klassiske P3-strømforsyninger. Dermed blir +12V kursen på det poweret du har idag sannsynligvis for svak for noe moderne CPU.
Den andre grunnen er at dagens PC'er bruker MYE mer strøm enn P3, så sjangsen er MEGET stor for at strømforsyninga mangler strøm på andre kurser også...
Og sist, men ikke minst; P4-hovedkort krever veldig ofte en ekstra kontakt, såkalt ATX+12V, for å levere ekstra strøm til CPU. Den kontakten har du IKKE på den strømforsyninga du har idag, og i beste fall vil dette 'bare' begrense sterkt hvilke hovedkort du kan velge mellom om du har lyst på P4.
Og når du først skal bytte; et nytt power koster så og si like mye/mer enn et helt kabinett MED strømforsyning... så... det er ofte like greit å bare kjøpe nytt kabinett MED strømforsyning... Så får heller den gamle maskina pælmes, settes opp med Linux, ruter til bredbånd, server, fotskammel....
