Aafloey Skrevet 1. september 2008 Del Skrevet 1. september 2008 (endret) Satt og surfa helt vanlig og fikk plutselig blåskjerm. Fikk en minidump og endte opp med denne analysen: Klikk for å se/fjerne innholdet nedenfor BugCheck 1000008E, {c0000005, 880320b0, b60e3368, 0} *** WARNING: Unable to verify timestamp for nv4_mini.sys *** ERROR: Module load completed but symbols could not be loaded for nv4_mini.sys Probably caused by : nv4_mini.sys ( nv4_mini+83c4b ) Followup: MachineOwner --------- 3: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e) This is a very common bugcheck. Usually the exception address pinpoints the driver/function that caused the problem. Always note this address as well as the link date of the driver/image that contains this address. Some common problems are exception code 0x80000003. This means a hard coded breakpoint or assertion was hit, but this system was booted /NODEBUG. This is not supposed to happen as developers should never have hardcoded breakpoints in retail code, but ... If this happens, make sure a debugger gets connected, and the system is booted /DEBUG. This will let us see why this breakpoint is happening. Arguments: Arg1: c0000005, The exception code that was not handled Arg2: 880320b0, The address that the exception occurred at Arg3: b60e3368, Trap Frame Arg4: 00000000 Debugging Details: ------------------ EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - Instruksjonen i "0x%08lx" refererte til adresse "0x%08lx". Minnet kunne ikke v re "%s". FAULTING_IP: +ffffffff880320b0 880320b0 0000 add byte ptr [eax],al TRAP_FRAME: b60e3368 -- (.trap 0xffffffffb60e3368) ErrCode = 00000002 eax=00000000 ebx=8a169008 ecx=b93df150 edx=ffffffff esi=c1d00019 edi=00000000 eip=880320b0 esp=b60e33dc ebp=00000040 iopl=0 nv up ei ng nz ac po nc cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010292 880320b0 0000 add byte ptr [eax],al ds:0023:00000000=?? Resetting default scope CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: DRIVER_FAULT BUGCHECK_STR: 0x8E PROCESS_NAME: firefox.exe LAST_CONTROL_TRANSFER: from c1d00019 to 880320b0 SYMBOL_ON_RAW_STACK: 1 STACK_ADDR_RAW_STACK_SYMBOL: ffffffffb60e3434 STACK_COMMAND: dds B60E3434-0x20 ; kb STACK_TEXT: b60e3414 b60e3434 b60e3418 8a0b0cb8 b60e341c 8a1ae9b0 b60e3420 00000000 b60e3424 b60e3718 b60e3428 87ee0748 b60e342c 8a19b470 b60e3430 b9424c4b nv4_mini+0x83c4b b60e3434 00000000 b60e3438 00000000 b60e343c 00000124 b60e3440 b60e3548 b60e3444 00000014 b60e3448 00000000 b60e344c 00000000 b60e3450 b93f4256 nv4_mini+0x53256 b60e3454 8a19b48c b60e3458 00005c51 b60e345c 00005c00 b60e3460 b9417370 nv4_mini+0x76370 b60e3464 b93f4256 nv4_mini+0x53256 b60e3468 8a19b48c b60e346c 00005c51 b60e3470 00005c00 b60e3474 b963301b nv4_mini+0x29201b b60e3478 8a19b470 b60e347c 00005c51 b60e3480 0000001f b60e3484 b93e5b38 nv4_mini+0x44b38 b60e3488 8a1ae900 b60e348c 8a3339bc b60e3490 b9412c53 nv4_mini+0x71c53 FOLLOWUP_IP: nv4_mini+83c4b b9424c4b ?? ??? SYMBOL_NAME: nv4_mini+83c4b FOLLOWUP_NAME: MachineOwner MODULE_NAME: nv4_mini IMAGE_NAME: nv4_mini.sys DEBUG_FLR_IMAGE_TIMESTAMP: 482e0095 FAILURE_BUCKET_ID: 0x8E_nv4_mini+83c4b BUCKET_ID: 0x8E_nv4_mini+83c4b Followup: MachineOwner --------- Hva er det egentlig som er galt, firefox eller en xp driver...? Endret 1. september 2008 av Aafloey Lenke til kommentar
Svenni212000 Skrevet 2. september 2008 Del Skrevet 2. september 2008 Det har oppstått en feil på en nVidia driver. http://www.processlibrary.com/directory/fi...nv4_mini/418583 Reinstall av nVidia drivere vil jeg si er første logiske start. Lenke til kommentar
