Asus P5W64 Pro problem med å boote windows CD
Totti
Fant følgende fra en kunde-erfaring (12.11.2006), vet ikke om det er relevant for deg (eller om fyr'n er på jordet for den saks skyld)
be very afraid; known conflict with Western Digital Raptor hard drives: hangs on reboot. Bios forces end user to choose between legacy & 32-bit boot environment. If you choose the later, you can't boot with Partition Magic or any other CD disk utility that uses a DOS CD-Rom driver. Board won't recognize CD drive. None of the Beta bioses up to 3.03 will fix boot issues.
Satt og tenkte litt på dette her.. Vil det hjelpe å resette bios da uten en raptor disk tilkoblet?
