floydpink Skrevet 28. august 2008 Del Skrevet 28. august 2008 Hei. Jeg trenger et skjermkort med støtte for HDMI (både lyd og bilde), full HD (1080P) og god nok 3D-støtte til å kjøre Vista brukbart. Det er veldig viktig at skjermkortet har passiv kjøling, ettersom lydnivået må være lavt. Har dere noen anbefalinger? Lenke til kommentar
Svenni212000 Skrevet 28. august 2008 Del Skrevet 28. august 2008 Da er ATI 36xx eller 38xx serien uten særlig tvil de beste valgene. >> PowerColor Radeon HD 3650 512 MB SCS3 o ATI Avivo™ HD Video and Display Platformo Dedicated unified video decoder (UVD) for H.264/AVC and VC-1 video formats o High definition (HD) playback of both Blu-ray and HD DVD formats o Hardware MPEG-1, MPEG-2, and DivX video decode acceleration o Motion compensation and IDCT o ATI Avivo Video Post Processor o Color space conversion o Chroma subsampling format conversion o Horizontal and vertical scaling o Gamma correction o Advanced vector adaptive per-pixel de-interlacing o De-blocking and noise reduction filtering o Detail enhancement o Inverse telecine (2:2 and 3:2 pull-down correction) o Bad edit correction o Two independent display controllers o Drive two displays simultaneously with independent resolutions, refresh rates, color controls and video overlays for each display o Full 30-bit display processing o Programmable piecewise linear gamma correction, color correction, and color space conversion o Spatial/temporal dithering provides 30-bit color quality on 24-bit and 18-bit displays o High quality pre- and post-scaling engines, with underscan support for all display outputs o Content-adaptive de-flicker filtering for interlaced displays o Fast, glitch-free mode switching o Hardware cursor o Two integrated dual-link DVI display outputs o Each supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)2 o Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content3 o Two integrated DisplayPort™ outputs o Supports 24- and 30-bit displays at all resolutions up to 2560x16001 o 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane o Two integrated 400 MHz 30-bit RAMDACs o Each supports analog displays connected by VGA at all resolutions up to 2048x153622 o HDMI output support o Supports all display resolutions up to 1920x108022 o Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (5.1) AC3 enabling a plug-and-play cable-less audio solution o ATI Avivo™ HD Video and Display Platform con't o Integrated AMD Xilleon™ HDTV encoder o Provides high quality analog TV output (component/S-video/composite) o Supports SDTV and HDTV resolutions o Underscan and overscan compensation o MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding o Seamless integration of pixel shaders with video in real time o VGA mode support on all display outputs Lenke til kommentar
