Oppgradere fra 32 til 64bits XP
Q. Can I upgrade from 32-bit Windows XP Professional to Windows XP Professional x64 Edition?
A. No, you can't upgrade. You can use the Technology Advancement Program until the end of July, 2005, to exchange your copy of Windows XP Professional for the x64 Edition of Windows XP Professional, but doing so replaces your existing license with the new license. The actual installation of Windows XP Professional x64 Edition is a fresh install, not an upgrade. All your programs will have to be reinstalled, and if you have data on the same drive as your operating system, it will be wiped out. Make a thorough backup of your important files before doing the installation.
( http://www.microsoft.com/windowsxp/using/6...sel_x64faq.mspx )
Dette gjaldt kun dersom du hadde en retail XP 32bit Professional lisens.
Men det kan kjøpes en OEM XP Pro x64 til ~ 900,-
http://www.amentio.no/PartDetail.aspx?q=p:1520597;c:36276
Endret av syar2003
